DMG MORI gearMILL
Downloads
Technical data
● available
Vertical Machining Center for Workpieces up to 2,000 kg and large Y travel of 700 mm
Vertical Machining Center for Workpieces up to 3,000 kg and large Y travel of 700 mm
CNC Universal Milling Machine with swivel rotary table
Travelling column machine of next generation for 5-axis simultaneous machining
Hybrid Complete Machining: Additive Manufacturing and Milling in one Machine
Laser Metal Deposition & 5-axis machine
Traveling column machine of next generation for 5-axis simultaneous machining
The entry machine for 5-axis simultaneous machining
5-axis simultaneous machining of workpieces up to ø1,040 x 590 mm and 1,000 kg on 12.3 m²
Turn & Mill production redefined
- 2x Turn & Mill spindles up to 20,000 rpm and 49 Nm for highest productivity machining complex parts
 - Bar machining up to Ø 72 mm, chuck parts up to Ø 250 mm
 - Maintime parallel tool change due to 38-fold tool magazine for each spindle
 - Retractile tailstock for long parts
 - Automation: Integrated workpiece unloading, bar feeder, gantry loader or robot automation
* available from Q1/2026
Next generation of SWISSTYPE machines
